Stereo sound issue
Martyn Cannon
London NW7
www.tithefarmclub.com
S500 2001 , CLK 320 Sport Auto 1998, Porsche Boxster 2.5 Manual 2000
Can anyone help
I have lost sound output from the system everything comes on but no sound
Any ideas
Martyn Cannon
Martyn Cannon
London NW7
W220
Where is the amp hidden maybe the fuse?
HK sound system?
Martyn Cannon
Martyn Cannon
London NW7
No idea it has Bose speakers
Amps failing in W220’s is unfortunately very common :(
Any way to be sorted out ?
Some people have had them repaired but with very limited results, failing again quite quickly and then having issues with the companies that repaired them.
Second hand ones are available but usually as bad as what you have already.
New amp is the normal fix which is expensive
Martyn Cannon
Martyn Cannon
London NW7
It also suddenly stop seeing the CD changer cartridge say no cartridge but if I ejected and re inserted it would see it
Flyinspanner
Ruislip
The amp is in the boot under the CD player.
It’s easy to take them out.
They are both mounted in the same frame/bracket.
If I recall correctly, there is a blade fuse on the amp itself as well.- you may be lucky :)
Check the area for dampness, as that seems to be an issue sometimes (boot seal).
You can pick replacements up on eBay, they are the same on the W215 (and with a bit of trimming of the socket receptacle with a scalpel, you can get a same year CLK amp to fit as long as it is also a ‘Bose’ one).
With regard to the “no magazine” pop the cover off the CD player, you will find the cartridge mechanism keyways are a bit gummed up with the old grease.
Careful cleaning with Q tips and isopropyl alchohol, then fresh tiny amount of a very lightweight silicon grease may resolve it sticking.
if not there’s a bloke on the bay who does refurbed units for £45 :) I’ll try to find the link.
https://www.ebay.co.uk/sch/car-radios/m.html?_nkw=&_armrs=1&_ipg=&_from=
Maybe he hasn’t got one in, but he may refurb yours?
Martyn Cannon
Martyn Cannon
London NW7
Great I’ll have a look in the morning there is deffo dampness near the CD players
Flyinspanner
Ruislip
Trace & cure the damp, or it may blow any replacement. Check your boot seal and drains, :)
Martyn Cannon
Martyn Cannon
London NW7
So fair bit of water in the housing so have dried that out
Changed the blade fuse 20amp but other seemed ok
Still reading no CD Changer and there is no power to the Cd changer as cannot eject the cassette
Should I now unbolt and further investigation?
Flyinspanner
Ruislip
Get a multimeter and see if there is 12v at the CD supply plug.
If not, check the main cd power supply fuse.
might be worth taking it all out and sit it in a bag of dried rice in a warm place for 24 hrs in case it is damp?
www.W140.co.uk&www.r129.co
