Devon
- Oct 20, 2009
- Location
- Mid Devon
- W210 E200K Estate + BMW 320 Gran Turismo
I am still running my old E-class S210; a 2001 E200K (auto) estate.
I have had it for 18 years and although it is looking a bit dog-eared nowadays, I am loath to get rid of it. A capacious old bus, it is so useful for many purposes.
In 18 years it has never left me stranded despite having covered dozens of long continental journeys.
However, recently it has developed a brake problem: the brake pedal is failing to return fully and the brakes are binding. This starts after about five minutes use. Initially the pedal functions as normal but after five minutes or so starts to stick and I have to pull it back up with my toe. One morning I found I was unable to move the selector out of “park”. I checked the battery voltage, which was ok (about 12.6v) so I then replaced the brake switch and that cured the selector problem but the sticking brake pedal remains. I have gone through the basic pedal pressure behaviour checks to try to isolate the problem and as far as I can tell the master cylinder and servo function seem ok. The vacuum pipe to the servo is working ok, and disconnecting the plug at the diaphragm position (BAS) sensor made no difference.
But something is holding the brake pedal partially on when it should not be.
Apparently there is a solenoid switch built into the servo unit but I do not know what its function is. Could that be the root of the problem?
Any advice would be greatly appreciated.
