Sticky parking brake
drmw
Yorkshire
www.autonomed.co.uk
Hi - I don't normally use the parking brake, but for some reason I did last evening. I didn't press the pedal very hard, so when I got in to drive off this morning I was able to reverse off the drive & start moving forward before it told me the parking brake was on.
I pulled the release, but it didn't do anything (my last model gave a good "clunk" when it released). I tried a couple of times to no avail, then actually pressed the pedal a bit harder in case it is the spring on the pedal itself that disengages the system when the release is pulled. Took me quite a few pulls before the thing released (although it didn't "clunk" so I was unsure until I drove off if the damn thing was on or off!) :mad:
To save me some time, can anyone explain where on an R230 the mechanism needs to be lubricated and / or adjusted?
many thanks
David
All around 120 in thislink. also do the ends of 210 and 220 on the levers where the cable attaches
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
Thanks for that Malcolm - I can feel the gravel rash on my back already !! :D
Do use oil or silicon, and not WD40 the spring may have broken on the pedal, that was 30 in the last link,, the clicking 40 bit is for sound only
drdre78
london
mercedes c200 200
hi if it c class you need to lift up back seat and remove cover and undo nut and you find cable is slack and all need to do is tighten up nut.just couple of turns or do it to much handbrake be on at all times
spooky1
enfield
C180 KOMP ELEG.SE
Put in reverse sling it backwards.
As you say why ????
The SL has no seats in the rear,and not possible from within the car
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
Thanks guys - the "fix" was simple & ran along the lines of "if in doubt, give it some welly" before breaking into a sweat
A few off/on operations pushing the brake pedal down firmly & releasing seems to have persuaded it to behave itself - it probably just thought about taking its bat & ball home as it felt neglected :)
www.W140.co.uk&www.r129.co
