still a query about my autobox
traviski
hi all
sorry to be a pain in the backside butwas reading a thread last night about atf been filled with water from the trans cooler in the rad now when i sorted mine on friday ie put atf in the box because was showing none on my dipstick could my atf be going into the water or is it always water going in to the atf if ya know what i mean
could my car be affected by this situation it is a c class sport auto on a 99 plate it is the square headlight model
thanks in advace
David Nock
South Yorks
CLK/2009/320CDI
My understanding is that there is always more pressure in the coolant system so it's a one way route into the auto box. Besides, if it were the otherway you would have coolant/ATF fluid mix rising in your radiator system and you would see it. Any expert care to confirm this?
T
traviski
thanx for that have checked fluid level again today and its just above the min mark so now i know where its sitting at i will kep an eye on it for a few weeks
Parrot of Doom
Manchester
You need to get under the car and look for leaks. The ATF will be going somewhere, it may be pooling on the plastic trays under the car.
T
traviski
thanx for that parrot i was just looking on my drive for a wet patch
