Stolen key
P
peejayX
Hi, new to this site, can anyone advise? I had a break in last night, and my key ring was stolen. They did not take the car, but I'm worried they might come back for it. I have a spare key, so I am able to drive it. Is it possible, and how much to change electronic frequency so the stolen key will not work anymore.
Welcome, but not with your not such good news
This is a difficult area, and I think that MB can cancel some keys, on the basis that they will only sell 6 replacement keys, and the old ones have to be canceled. Any help on this would be appreciated on clearing this grey area.
If the worst comes to the worst, 2 new keys and a new ignition switch will be needed at a cost of around £1000.
I think that your house insurance should cover the cost of this work as the part of the car was taken from the house, and not from the car.
I will talk to MB today and try and get a clear answer
Cole@MBS
www.mbssouthampton.co.uk
Your dealers can remove the stolen key track from the EIS (uncode it from the car) sorry to hear about the break in!! and welcome!!
Thanks SAM,I thought that they could do that but was not sure as in my post.
Thank you again
GCLTuning
Banned
Suffolk
www.gcltuning.co.uk
Yes you will need to get the current key Re-coded with a different Key code .
The other key will then not work if you order another key this will need to be done at the same time or you will need another code
1 Code = as many as three Keys at one time
1 code one key - If you add another you will need a new code
Regards
P
peejayX
Thanks guys, looks like a trip to MB.
P
peejayX
Thanks again all, one more question, I have to disable it tonight incase they come back for it before I can get it sorted. If I disconnect the battery, will I be able just to reconnect it in the morning and drive away, or will I have hassell resetting electrics?
BlackC55
South coast
C43
I would not just take the battery off as they have your key and can gain acess to the battery easily.
Disconnect somthing else too.
Top Cat
Milton Keynes
(97) W202 C230 Elegance Estate
Maybe pull off some/all of the HT leads and take them in the house with you - I've done this once in the past when staying overnight in a slightly dodgy area.
Would it not be possible to park with a friends house and their car behind yours
P
peejayX
Survived the night, and my cars still here. Borrowing a heavy duty wheel clamp today from a car dealer, untill I get it booked in. Thanks all.
Cole@MBS
If you say what model it is i could tell you how to dis-arm the car!!
It's a CLK 320 - 2003
I take it it is a early 209 and not a late 208, If its a 209 then undo the front fuse cover, disconnect the purple wire, that cuts the starter feed or disconnect the fuel pump relay in the rear sam,bottom relay!
S-a-m/ u-n-i-t (on a day trip to West Country by Sea!)
P
peejayX
Malcom, thanks so much for all your help. Peter
SAM wrote out the above today on my computer, so please thank SAM and not me, I needed the post count point :D
