Strange rattling noise under C200 W203
ionod55555
I have a strange rattling noise under my car that sounds like a loose clamp or similar. It can be heard when going over humps or slightly uneven road surface. I also have another strange noise from the rear that sounds like bouncing noise of a spring, again when going over humps.
Lastly, does anybody know of a good indie in the Chiswick area.
Can anybody help.
Thanks and regards
ionod55555
C
C180 Chris
I have this on my S320, general opinion seems to be that its the Anti roll bar bushes, or drop links.
Also may be worth checking the wheel bearing on that side as i think that mine is adding to the clatter over bumps.
Hope this helps, others will be along soon with more advice!!
The exhaust heat shields are known to come loose causing a rattle
I
ionod55555
Rattling Noise W203
Just to add to my thread,
The strange noise only seemed to have developed after using the hand brake last Thursday!!!! Would anything have come adrift? I don't normally use the hand brake at all and Thursday was probably the first time in approx 2 months.
I don't know if that helps pinpoint the noise.
I
ionod55555
Just returned back from Kwik Fit after having A/C de-bac. While there I had a good look underneath for the rattling noise but found nothing. Bushes all seem ok, so does the springs, exhaust baffles and handbrake linkage. Wheel bearing don't seem to have any strange rumblings or play.
Any other suggestions where I could look or if somebody in the Chiswick area can have a look for me please.
Regards,
ionod55555
Just reading the post again I know what the problem is.
On that V6 the cats come loose in the bottom boxes, it happened to me and many others, they are expensive, so many of us cut open the bottom boxes and remove the CAT and weld up.
They still pass the MOT as they have upper cats as well
Andrew23
Teesside
2008 E280 Elegance saloon
..."I also have another strange noise from the rear that sounds like bouncing noise of a spring, again when going over humps."
ionod55555
Hi.
I recently had a strange springy boing on the rear - turned out to be broken springs. Aparrently (so I read somewhere on this site) they often break towards the ends so it is not always obvious that they have actually broken. May be worth checking.
Cheers,
Andrew.
I
ionod55555
Thanks for that Television and Andrew. The more I listen the more it sounds like a loose clamp or something, comes and goes but is always there when going over humps. When on the ramp, i bounced it up and down but no noise!! As soon as I drive off it starts when I get to any uneven surface.
My car is a 4cylinder by the way, would the same apply to the cat?
Will soon be pulling the remainder of my hair out if this keeps on. Don't really want to go to MB main dealers but might have to if it continues.
Regards
ionod55555
I
ionod55555
Took car for a long drive today and the strange rattling noise is coming from rear. Folded the rear seat down and the rattling noise increased. No obvious items in the boot that could cause it that I can see.
The hunt continues!!!
Regards,
ionod55555
Could it be a loose baffle in the exhaust
West Sussex - UK
I had the anti-roll bar thingy on the front suspension and it sounded like it was coming from the back of the car. Had MB change them (not very expensive) and it went away.
I also had the "other" rattle that Malcom mentioned, the cat one. That was VERY expensive. Even Kwik Fit wanted over £2000.00 to fix it. In the end I bought a cat from www.cats2go.co.uk for about £150.00 and the local garage fitted it for about £50.00, so it can be done cheap(ish).
However, if it's only on lumpy roads (the cat was pretty much constant when the engine warmed up. Blip the throttle and you'll hear it rattle as the revs die down), then it sounds like these drop-link, anti-roll bar thingies on the front suspension. It is a VERY common problem on the C-Class but pretty cheap and easy to fix.
I
ionod55555
Having new springs and shocks fitted tomorrow, will have drop arms etc checked at same time. They were replaced last year however by MB of Epsom amongst other items. Went out over the weekend with 5 people in the car, rattling noise stopped for a day or two after but has returned again. It sometimes sounds like the shield around the disc caliper rattling but checked them yesterday. I don't know where else to look. It's not from the exhaust as tried reving engine, tried shaking the exhaust pipe, even tapped it along it's length for rattles but nothing. Emptied boot of everything inc spare wheel and still get the same noise.
rapidly going mad!!!!!!
britnordic
Cambridge
2006 SLK 200 & 2013 E Class 220
I know just how you feel!
Posted a similar thing happening to my C203 Estate, rattle came for a day or 2 then left!!
Turned out to be a broken spring (common fault on C203) break was hidden in housing so couldn't be seen, but MOT mentioned springs looked low, so got my local Indie to replace (thanks JiB!).
All silent now.
I
ionod55555
Had new springs and shocks fitted at Kwik Fit yesterday and all strange noises have gone and car handles better.
Thanks to all for the replies and suggestions related to the post.
Happy and less stressed
ionod55555
GSM1
Glasgow
Springs and shocks on mercs should come from the main dealer only, they are very specific to the model, classic, avantgarde etc.
i had mine done and there was many variations from the dealer. Kwik fit will have used eurocar parts or a similar factor
I
ionod55555
  • #18
Shocks and Springs
Hi GSM1,
When I went to Kwikfit, I went through all the variations they had, the list was endless. We finally found the right ones after supplying them with all car details. They have at least 2 years guarantee on both, so any problems and I will be straight back there. I probably would have changed cars by the time the guarantee expires anyway.
Regards
ionod55555
cozymerc
Essington staffordshire
Mercedes 190e Peugeot Coupe and Chrysler Grand Voyager.
Brake pads clatering against the brake disc try braking slightly when driving over rough surface to see if the noise stops handbrake cable may be tight reducing the distance between brake pad and disc get under neath and tug on the hand brake cable to losen it.
