sun roof
w123rob
laindon essex
my w123 230c 1979 pc leaks from the sun roof where are the drains to clean out and where is the motor located as the roof can be opened and closed but is very slow or keeps requiring me to pump the button to close it.......also how do you remome the headlining ta w123rob
turnipsock
Port of Menteith
if it's the same as a W124 it will be at the nearside rear.
There is a relay in there that might need some attention.
http://www.detali.ru/cat/oem_mb0.asp?TP=1
Find you car 123--- by the vin, scroll down and find sliding roof its all there for you to see. once lubricated with a good PTFE spray or something similar it will be OK
malcolm
turnipsock
Port of Menteith
It's near the motor. Remember I'm talking about a W124 here.
I had to remove mine and clean up the pins. The sunroof worked fine after that.
