Sunroof wont close properly !! Help
Chas
Scotland
S320
The sunroof on my S CLASS W220 2001 wont close properly.
It opens fully ok and slides back properly . It also tilt opens ok.
When I close it with one touch or full touch it slides close from back to front and opens up into the tilt position as it should and when it comes down to close fully it stops about 1 inch from close in tilt position.
I cant see any obstructions, and have tried the reset thing......holding open button for 5 secs and holding close button for 5 secs.
I have managed to get it in the close position by fidlling with the open/close button but the car still thinks it's open .........close sunroof warning message......when I take the key out !!
I took the key out the car when the sunroof was open if that is any help? The problem started after that :confused:
Any ideas folks ??
thanks
Chas
Chas
Scotland
S320
  • #2
This excellent post might be the answer........... I didnt do the reset properly !!
http://www.benzworld.org/forums/2217418-post14.html
Synchronizing sliding/pop-up roof:
If the power supply was interrupted (battery disconnected or low), or if the sliding/pop-up roof is blocked during closing/opening procedure, the system has to be synchronized. To do so, turn electronic key in steering lock to position 2, move and hold switch in direction (3), until the sliding/pop-up roof is completely raised at rear, and hold for additional 1 second. If the pop-up roof simply will not open or close all the way after using this procedure, clean the tracks and lubricate them with the MB lubricant made for the purpose.
Thank those above as there is not a listed fault for this:D:D
Chas
Chas
Scotland
S320
I have tried the reset and no luck. I have also lubricated and checked for any blockages.
I will try the manual key wind behind the overhead lighting panel cover.
Failing all above I am stumped :confused::confused:
HELP !!!!!!!!
HELP !!!!!!!!
See what I can find around mid day :D:D
Chas
Chas
Scotland
S320
Cheers Malcolm
Chas
Chas
Scotland
S320
Will diconnecting the battery reset it?
teddycatkin
cheshire cheese country
Diagnostic plug in at dealers and re-sett fault as a last resort !!
(unless you are matey with any of them ?-they may do it for free)
Sliding roof loses its normalization = change the OCP unit
I have sent you all details
Chas
Chas
Scotland
S320
Thanks Malcolm for the details.
A battery disconnect could very well clear the OCP fault. Failing that a STAR diagnosis and or replacement of the OCP should do it.
Lets hope the battery disconnection works.
How do I disconnect the battery properly and what precautions do I need to take.
Will I need to reset a lot of things?? like in this link............http://www.benzworld.org/forums/2217418-post14.html
The only thing to set will be the steering and the windows and then the roof, if it will
Just take off one battery connection
Chas
Chas
Scotland
S320
How long does it need to be diconnected for?
Chas
Chas
Scotland
S320
Thanks Everone .................result :lol:
I disconnected battery and 20 mins later held my breath as the sunroof closed after the reset procedure
Thank goodness for that :mrgreen:
