Suspension Part Numbers
SimonRaf
Belfast
CLS 220 Bluetec AMG Line Premium Plus - Palladium Silver
Hi all. Bit of a long shot but just wondering if anyone could give me the proper names of 2 suspension parts I have. One is an arm and the other a "bush" ?
They should be for a W203 Coupe, but on looking at the 1st part no. it starts with a 204?
Part 1 - (Arm) - A 204 330 44 11
Part 2 - (Bush?) - A 203 333 10 14
Many Thanks.
type49
More info needed!! There are 4 arms on the front & a few bushes. There are 8 arms on the rear & loads of bushes.
SimonRaf
SimonRaf
Belfast
:Oops: Thanks,
The arm was for the front drivers side suspension (bottom) ?? Wondering if I phoned the Merc parts dept would they be able to search the no's and tell me the part name?
Goodjob
The bush is the thrust arm bush (or thrust arm bearing)
The arm is shockingly the thrust arm. It is the upper arm if you like since the lower arm is often called the thrust arm as well
Goodjob
meant to ad these are common parts and most dealers should stock these
SimonRaf
SimonRaf
Belfast
Cheers Goodjob. Reason I am asking is that I have them in my garage at home and was going to put them on e bay so need to know I am advertising the correct part :Oops:
