will remember that, hope someone will point out ,across which wires on 0m651. i will plan for manifold seals in the future ,clean and fit the resistor as i think it,as std is a crxx system primarily designed to have me at the stealer, same goes for DPF maybe i could get an old one,carefully open it ,clean out the guts and re tig it so no one aware ? that would be 2 looming headaches less.
