Hi. The lever to brng down the rear seats on my @240 estate is broken so I can not lower the rear seats. Does any one know hoe difficult it is to repair this? Thanks for your help.
I had the same problem with the 'small' rear seat on my C Class. Fortunately it was still in warranty but it took the dealer a couple of hours to strip out all the trim to gain access to the mechanism. Luckily they didn't cannabilise any of the trim as I understand this can often be the case. Apparently a very a common problem. Probably best to find an Indie with experience of resolving this problem.
