T240 estate rear seats
kildair
Hi. The lever to brng down the rear seats on my @240 estate is broken so I can not lower the rear seats. Does any one know hoe difficult it is to repair this? Thanks for your help.
K
kildair
  • #2
Pls someone must have some experience of this.......
If you do a search on this there are many post on how to fix,,this will be a cable catch problem and often means lift the corner of the backrest
moosehead
C230/2005/2.5L Avantgarde SE Sport Pack Estate, SLK230/1999 and Volvo XC60/2017 AWD
I had the same problem with the 'small' rear seat on my C Class. Fortunately it was still in warranty but it took the dealer a couple of hours to strip out all the trim to gain access to the mechanism. Luckily they didn't cannabilise any of the trim as I understand this can often be the case. Apparently a very a common problem. Probably best to find an Indie with experience of resolving this problem.
