Tail light issue E220
Risky Goat
Hi all,
One of my tails lights seems to be faulty. Does anyone have any idea what the possible cause might be and how to fix 40983E9E-A8A8-4C20-83D5-6B9A0661D7FD.jpeg ? i.e. fuse, lamp, cable etc?
Thanks I’m advance for any suggestions.
malcolm E53 AMG
This might help - looks like the problem could be a soldered dry joint
mioba
Nottingham and Köln
fuse - look in the fuse box for blown fuses.
Lamp - doubt it as the entire cluster is out which points to voltage.
So get a voltmeter on the connection and see of there is voltage going into the cluster. if Y, then a cluster fault.
Lamps are easy to test for continuity.
Simple process of elimination.
R
Risky Goat
Thanks, I was really just wondering if there was a common fault before starting the in ravelling process.
