Telephone, parking sensors.......
00slk
Cambridgeshire UK
And passenger auto mirror adjust have stopped working. :(
Can someone point me in the right direction of the appropriate fuse.
Hoping it is just a blown fuse? :rolleyes:
Cheers Peter
Cheers Peter
Which one of your water features has this particular issue?
00slk
00slk
Cambridgeshire UK
Oh silly me, the dry car :rolleyes:
S211 :D
Sounds a bit like a SAM failure, they get wet and things stop working...;)
00slk
00slk
Cambridgeshire UK
I would have expected from the r230, but not a water tight E Class :rolleyes:
I certainly will be :shock:
I seem to remember front SAM’s on 211’s had a water issue, although I may have dreamt it...
00slk
00slk
Cambridgeshire UK
Do you know where the SAM unit is Rus?
00slk
00slk
Cambridgeshire UK
00slk
00slk
Cambridgeshire UK
Its' the "other" passenger side...;)
I see you've taken the lid off in your other pics today
Oh, der silly me.
Yes and I have had a poke around, maybe find the fuse and remove it, check it and refit it, if its's okay try the phone again?
Oh, der silly me.
Might be worth taking the cradle out and re-seating it. You can get poor connections overtime
00slk
00slk
Cambridgeshire UK
Thanks Rus. I think that can be a job for when the weather improves a bit and I have the 55 here again. I can really mess up with any thing electrical you know. :(
It's a cradle in the armrest, unless it's leaking worse than the SL you should be ok... ;)
00slk
00slk
Cambridgeshire UK
  • #17
Haha, see how good I am at electrical
It's a little lose sitting in there but won't pull out. Further investigating I think.
It should clip out, can't remember if you need to press down that button first (or if that is just to sync it with your mobile)
It's been nearly 10 years since I had a W211
EmilysDad
Bury Lancs
ML350
Pretty sure it unclips using the little button ..... doesn't it then slide to remove. The bit where it says 'Bluetooth' is the button you press to sync it with your phone :)
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
I believe the button to release the puck from the cradle is on the side.
It is on the Nokia cradle and the Viseo bluetooth unit.
