Testing A/C Compressor V230
matteb63
Abergavenny Wales
Cl 500s & CLS500 with LPG conversions
How can i check if the A/C compressor works before having someone fill the system . Im currently changing the head on the engine and before I start buttoning it all up I wanted to test the A/C compressor ..If it is faulty then I can replace it before I put back the head
Matt
The A/C is a W140
A0002342411
Only by sending away, I do not think that you can test it your self
LYNALL
Kent
Needs to be connected to air con regas machine does not need engine running to gas it up but will need it running to check pressures etc.
Did it work before you stripped the motor? rare for compressors to go wrong.
Lynall
