Jimmyboy
SLK 200K WDB170 miles 90,000 miles 2001
Hello, I have been reading a recent post by 'Knowlap' regarding ABS and ESP faults. 'Television' advises that my problem is a wheel speed sensor. I have looked behind a front wheel but am not sure how to get the sensor off. It appears to be behind a plate and cover held on with two quite substantial torque screws. Also the cable goes up and through the wheel arch where it joins up with the brake wear sensor cable - cannot trace any farther. Could someone please advise:
a) Can I safely take off the plate/cover and pull the sensor out?
b) Does the cable disconnect from the sensor so I can check the resistance?
c) What approximate resistance value am I looking for (a few ohms or kohms)?
d) Are the rear sensors a similar arrangement?
e) I assume the sensors are just two wire??
f) Any other tips MOST appreciated.
Many thanks for help.
Jimmyboy
Jimmyboy
