Austy
- Mar 16, 2018
- 1998 SL320 2003 CLK270CDI 2004 E320CDI 2006 CLS320CDI
Hi Guys. I think I have a slow drain, battery would be flat if left for even just 1-2 days which imo shouldn't be normal regardless of the amount of electrical systems in the car (Alternator and battery are fine).
I tried to test for a drain with a multimeter (set at 10A DC) and pulling fuses 1 at a time. I obviously needed the boot lid and driver door open so I manually closed the boot and door locks, and clamped the interior light button on the drivers door pillar. Locked the car and left to rest for an hour.
When I came back to the car to perform the test I removed the negative cable from the battery and connected the multimeter in series. This caused the indicators to flash which obviously caused flux to the readings rendering test useless. I didn't see the indicators at first but I could hear the fast click from the dash, they were flashing fast as if the alarm was activated (alarm was prev disconnected as it causing a key fob locking issue)
Have I missed a trick somewhere? Is there something else I should/shouldn't be doing? Any advice appreciated.
