Thanks for the add I have a 2008 cls 320 cdi
James Williams 1967
Cls 320 cdi 2008 219
I have done the injector seals on my engine but when I’ve tried to start it it turned over a couple of times then stopped a message appeared on my dashboard ebs inop run flat inop battery sign lit up red and the cooling fan running fast any solutions thanks in advance
A.J.
Norwich. UK
Hi James welcome to the forum :)
James Williams 1967
James Williams 1967
Charge battery full, then find out what drained it.
Hi I’ve charged battery and it still won’t turn over still got message esb inop run flat inop and also the radiator cooling fan is running at high speed when I turn ignition on but won’t turn over any advice thanks in advance
mersum1es
Finland
I sounds you have no enough voltage to system. What does battery voltage (measured from poles) shows? Have you cheked all fuses, included big ones in passenger footwell?
James Williams 1967
James Williams 1967
Hi I’ve just looked for the fuses in the passenger footwell but there’s none there the only big fuse I’ve found is by the battery in the boot a 40 amp can you let my know were the other ones are located if any thanks
James Williams 1967
James Williams 1967
The battery post reading was 12.55v
mersum1es
Finland
mersum1es
Finland
I’ve removed that panel in the passenger footwell and there was no fuse panel there do you think it will be on the driver side right hand drive ?
No idea... under that metal plate was nothing?
James Williams 1967
James Williams 1967
Hi just an update it turned out to be a 25 amp fuse at the back of the fuse box under the bonnet just got to wait for leak off pipe O rings I ordered some off eBay but they were too big I work away all week so I can only do maintenance at weekends
Tel: 020 8863 9233
