Russel Weston
Well gents, I do promise that I am not only here to pick your brains.However you seem to be a good source of reliable and cheap information so here goes. 1981 230 223, when starting, will fire immeadatly then die, this will happen for 3 tries, on the 3rd it will run all be it with a missfire. After a minute or so, it will settle down and run fine. Pulling off will be fine but with a bit of acceleration it will just die. It will then restart first time and will not give a single problem for the rest of the day. This has been going on for about 2 weeks now. I have used Nitrox Injector cleaner. Checked and cleand Dist cap and Rotor, replaced on advise less than a 6 months ago. As the fuel regulator gave trouble, I have bypassed that, fuel pump has been stripped and cleaned, but I didnt replace the filter, it looked quite new(and I did the work Sunday afternoon). Any suggestions would be appreciated. I have been doing loads of work on her, replaced front right wing, T-cut the engine bay and underside of the bonnet and replaced both bumpers and am now working on the rust on the doors. Thanks in advance.
