ajlsl600
- Nov 18, 2013
- Location
- france
- clk3202001,sl6002003 with everything regrettably sold ,A class 170cdi auto. NG/TF1800 ML250
The click could be the starter relay. This is why I asked him to identify where the click is coming from.
Agreed about the fuse.
bad spot on commutator ? if you test wiring to starter and cant find ussue try a substitute earth to the starter , ie jump lead ,batt earth to starter body/bolt, not any wired fitting. or as close as you can get. if that dont prove anything think you may have to substitute the starter motor. that click , its just a relay type sound, ? not the sound of bendix whacking the ring gear? most motors stop at the same point on flywheel and can over time cause issues .. obvious question , battery in good nic ? put lights on try to start .lights go dim .if not batt prob ok
