The connected device is not supported
Chris2fer
E200 AMG estate
IMG_20210515_202740328.jpg i can not get my android phone to connect to media to enable Android Auto ..I can connect via Bluetooth..but not thru usb
BillyBoy
W213 E400d All Terrain
Silly question, but are you definately using a data cable? A lot of (cheaper) USB cables sold in shops etc. are charging only.
C
Chris2fer
E200 AMG estate
Not a silly question .Billy I tried with the lead that came with the phone ...I will go out and buy a new lead
BillyBoy
I'll try on mine in a bit and see if I get the same. Have only tried the Apple Play up until now.
I'm guessing from the picture yours is a W213?
C
Chris2fer
E200 AMG estate
Just bought the car ...so much tech to get thru don't know what W213 is sorry
W213 is the chassis code for a late 2016 on E Class
BillyBoy
Sorry, it's the model version. The E Class W213 version is 2016 onwards, though there may be some late W212s from 2016 too. There's a good pinned thread in the General section, but you'll find a lot of folks on here refer to their cars by the "W" number rather than just model. Hopefully that helps
C
Chris2fer
E200 AMG estate
Ok I looked it up wow am learning a lot ...yes it's a w213 ...2018 e200 AMG estate ..
jimbg
E Class Estate 2020 220d Prem Plus
Not sure if it is important, but is it in the correct USB slot?
BillyBoy
Ok, just tried it in my car, and it only works if I use the USB in the "ash tray" (I know it's not an ash tray these days, bit don't know the modern name!)
C
Chris2fer
E200 AMG estate
Ooh ..I am such a newbie thanks
Anyway update ..I bought a new lead ..which had 5star reviews as android auto lead on Amazon ..still same problem ...
BillyBoy
I used usb 2
Does your car have a USB in the ash/trinket tray? My old E220d on a 66 plate only had the two sockets in the centre arm rest, but Apple Play worked on at least one of those - can't remember now if I had to use a specific socket and I never tried Android as I was on Windows Phone at the time for my personal phone. The All Terrain has a socket in the trinket tray as well as two in the arm rest, but the arm rest ones only seem to support charging and USB media, not Apple Play / Android Auto for some reason. MB kept making changes to the layout through the life of the W/S213 up to the facelift and things that were optional or part of "packs" became standard and others got deleted. I'm was disappointed that they have removed the rear seat switches from the wheel arch area on my All Terrain so you have to go to the boot to drop the back seat down whereas on the old one you could do it from either the boot or inside the read doors. I guess a bean counter somewhere has worked out they can save 37p a car by only fitting one set of switches :(
rorywquin
North Yorkshire
An old B-Class.
Pretty sure what some of the others are saying is correct - phone only works through one of the USB ports. They are clearly marked in my car...one for the phone and the other is for a usb memory stick / ipod etc.
C
Chris2fer
E200 AMG estate
Yes it states in the manual that usb 2 ..is for synching phone
We have tried to connect on both android and iPhone .. bought new state of the art usb cables ANKER +
Am going to take the car to my local Mercedes Benz this morning see if they can help
C
Chris2fer
E200 AMG estate
UPDATE!! ...I have been told by my local Mercedes that my Car need to have had CARPLAY or ANDROID AUTO installed from when it was manufactured ...bar hum !!!
