joderest
- Apr 16, 2018
- ML270 2003
A few weeks ago my wife ran over a pheasant in her Mini, she could not avoid it due to car coming other way, she does hate to run any thing over.
A couple of days later she rang me at work to say the tyre flat indicator had come on , i said not to worry and i will check when i get home. Checked all the tyres and the front drivers side was 4 psi down on the rest, pumped it up, and reset light and all good.
Then last week she called me at work again to say that the ABS light was on as well as engine management light. So told her to park it at home and use daughters car.
Put my scanner on it and it gave "wheel speed sensor fault".
Jacked up front drivers side and removed wheel, and arch trim and discovered that the Pheasant had entered that bit of the car, ripping all the wiring from the holders and the ABS sensor wiring had been cut through by the flywheel pulley.
New Sensor, tidy and fix all wiring and re attach to body, changed aux belt whilst in there, all back together, reset fault and all good.
Cost £46.00 all in and my time.
