vivijiv
- May 15, 2013
- Location
- Durban South Africa
- 1991 Mercedes 500sl
Hi I have just joined this forum hoping to get some direction on my problem.I have a 1991 500sl with acceleration slip regulation(ASR).
My problem is that the ABS/ASR light comes on when driving approx.30metres and stays on.This started ocuring after I had the vehicle serviced which included a brake check.
I have cleaned the front wheel sensors,replaced the brake switch and replaced the overvoltage protection relay but the problem still persists.I have disconnected and charged the battery,I have turned the steering full lock left and then right but with no luck.
The only sensor that I have not been able to find is the rear one supposedly on the differential.
Can someone point me in the right direction as to where this sensor is ,A drawing or picture will be useful.
Also are there any other reasons for this fault to persist and is there a test that one can do to check these sensors?
Thanks,
Vivijiv
Thanks,
Vivijiv
