tedfred
- Apr 29, 2018
- 2011 : SLK 200, AMG , R172 Eng' 271.861
Dear All,
I have noticed recently that the carpet on the RHS of my boot seem to be dragged out from under the rubber seal that retains it every time the roof is retracted. I also note that the rubber seal is damaged as it appears to be scratched as depicted in the images below. I also added an image of the LHS for comparison.
Unfortunately, I can not determine what is causing this problem as its impossible to operate the roof control and watch the assembly moving simultaneously.
Does anyone have any idea whether this damage is a harbinger of future disaster , what is causing this issue, how can it be rectified, could the rattle at the rear of the car when the roof is up/on indicate a slackness in the mechanism which may be the causing this issue, finally; do you regard this a s a warranty issue??
Thank you for your time spent reading this.
Regards to All
Tedfred
Regards to All
Tedfred
