the wine and ebay 124 CE 24v - update
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by lanciaman, Nov 10, 2012.
  1. lanciaman
    lanciaman Senior Member
    711
    3
    Sep 25, 2009
    Aberdeenshire
    Your Mercedes:
    E220 Cabrio (A124) - 1994
    Had a go at getting some rust out the rear arches today. That was good fun. Will post a couple of pics under bodywork.
    Seems to have an idling issue, cold or hot. Idles around 1000 revs at cold, but it isn't even, and when put into D it kind of bogs down so needs a bit of throttle. CPS has been checked and was just about 800 ohms (cold and warm). Mine has the MAS unit for the fuel pump relay but had it out and cleaned but it was not dirty.
    So dense question for today - where is the OVP relay on it? 1990/H age.
    thanks
    :confused:
  2. television
    television Always remembered RIP
    164,074
    279
    Your Mercedes:
    It should be under a plastic cover on the middle of the bulkhead
  3. OP
    lanciaman
    711
    3
    Sep 25, 2009
    Aberdeenshire
    Your Mercedes:
    off for a look! thanks Malcolm.:D
  4. OP
    lanciaman
    711
    3
    Sep 25, 2009
    Aberdeenshire
    Your Mercedes:
    Nope, definitely thick.....there is an ECU of some sort, then the MAS relay then the wiper gubbins..... see photo. Other side of wiper gubbins in brake master and then fuses and other relays (presumably in screwed down box under the screen, behind the fuses). :confused:
    Help! please.....
  5. television
    164,074
    279
    Your Mercedes:
    Its 119 and around there somewhere
    [​IMG]
  6. OP
    lanciaman
    711
    3
    Sep 25, 2009
    Aberdeenshire
    Your Mercedes:
    thing is, I know what it looks like - yet I still can't see it!!!
  7. television
    164,074
    279
    Your Mercedes:
    I will take a look on WIS for you :D
  8. television
    164,074
    279
    Your Mercedes:
    I have sent you all the pictures as to where it is and it is where I said;)
  9. macker64
    macker64 Senior Member
    148
    Mar 11, 2012
    Ireland
    Your Mercedes:
    1997 W210 300 Td & 1991 W124 300CE 24V & 2001 W210 320CDI & W210 E200 1992 W124 300ce 24v sportline
    Location of OVP Relay
    Lanciaman,
    Take a look at the attached photo of the OVP relay in my 1991 300ce 24v.
    The OVP relay is located on the RHS of the attached photo. Its the metal housing with the red top. Its secured to a metal frame via one screw.
    Regards,
      File size:
      480.8 KB
      16
  10. OP
    lanciaman
    711
    3
    Sep 25, 2009
    Aberdeenshire
    Your Mercedes:
    Thanks chaps. That is excellent. I didn't take the plastic cover off,only peeled it back.
    Will have a look tomoorrow to see if it is looking dodgy.
    cheers
    Lindsay
  11. television
    164,074
    279
    Your Mercedes:
    You have to open it up or try the one from your SL
  12. OP
    lanciaman
    711
    3
    Sep 25, 2009
    Aberdeenshire
    Your Mercedes:
    shall do...see if it reveals anything.
    .....SL doesn't have one......
    cheers
    Lindsay
Share This Page
