Thermostat or something else.
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
This little problem has been around for a while now and obviously not causing the car any harm but I want it sorted. So... Driving to golf this morning roughly 14 mile trip. car gets up to temp in about 11 minutes and sits at 87 degrees and stays there. On the way back however the car get up to around 80 degrees within 6 minutes then drops back down by about 10 degrees then goes up and down. If I give it some beans it goes up to temp and sometimes drops back to 70 or 80 when going down a hill for instance. This problem has been around 18 months. I can remember when it used to get up to temp and stay there and not move regardless.
grahamcol
West Midlands
2001 SLK230, 2007 CLK220 CDI
It'll be the start as you suspect. I've had exactly the kind of behaviour you mentioned on 2 Mercs in the past and similar behaviour with my newly acquired CLK. In each case a new thermostat has cured the problem, and in the case of the CLK fuel consumption has dropped dramatically.
grahamcol
West Midlands
I'm not sure Dean on your car but usually a stat is quite simple or at least used to be years ago. That said l got my indy to do all three of mine.
Dean Fletcher
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
I'll see if I can find any instructions on the net if not I'll fire it in the garage. Many thanks
Good luck. It shouldn't cost too much.
Depends if it’s a traditional thermostat or a new all singing and dancing chips with everything one... they are not in any shape or form cheap :(
grahamcol
West Midlands
Oh, OK. I bow to your superior knowledge. I was lucky with my cars then!
Dean Fletcher
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
Just done a quick search on ECP and CPFL and both come in at around 50 nicka.
malcolm E53 AMG
As above, usually £100-150ish for the stat mind you I wouldn’t be tempted to buy aftermarket, replaced mine a couple of years ago on the O642 from memory £120ish for the genuine stat, I would replace sooner rather than later before the DPF starts to play up
It's nice for once to find a part for the129 that's cheaper than later cars! £15 for the 129....:)
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
Or get a Mahrl (I can't spell it) off the bay as its the same one merc use. Its not worth saving a few quid on a non OM thermostat.
  • Like
Reactions: M80
M80
Derbyshire
Go to a reputable supplier,
I bought a Mahle intentionally from eBay, while it arrived in a chewed Mahle box the stat was unbranded.
The supplier argued but got it back anyway.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
My CLK was easy , 2 bolts and a slight fluid top up . Not sure where yours is on the car ? Buy one from MB would be my top tip
Nearly had to do that on my CLK270, it was stuck open & it was winter. But the 212 came along at the right price, so I just part exed it. It had 115K on the clock at the time.
Tel: 020 8863 9233
