- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
This bill is for a new door N69/2 door ECU, it did not fix the fault but no important right now. The actual fault was in the wire connecting the window motor to the ECU. I removed the door card as the window worked sometimes, they did not remove or replace the door film, they tore a 7" hole to get to the ECU. The original door insulation is still on the door.. All in all it took me 25 mins from start to finish.
On the bill it says
£48 to replace the ECU with door card removed
£67.90 to remove trim and install
£135.80 to replace and install door film
£29.10 for software
£210 for Door N69 ECU
Total with VAT £585.56
So £200 overcharged
On the bill it says
£29.10 for software
So £200 overcharged
