Thoughts on this E53 estate!
Srdl
New Forest, Hampshire
GLC43 AMG 2018 (X253)
Had Mobilo out today to look into the burning smell after 15 minutes driving and the result was no oil leak from the Turbo feed and return (which was the real reason I called them out) and it would seem the the car has a clean bill of health with no visible oil leaks so will so see how it goes.
There was one other thing of note his diagnostic tool was showing the PPF at 150mg (75% full) of soot so the car may have been trying to do a regeneration on the last three shortish journeys so will give the car a good run this weekend. It’s also likely that as the car is only on a quarter of a tank of fuel that that might stop a regen.
PPF regen was my initial thought. On mine, the fan sometimes runs for a few minutes after turning uff the engine to help things cool a bit.
malcolm E53 AMG
malcolm E53 AMG
  • #462
Unlike the S212 with the OM642 diesel engine it’s not obvious when the PPF is doing a regeneration with the M256 petrol engine and to add more complication I’ve changed over to E5 fuel (1st tank full) so I’m not quite sure what is happening at the moment. I’m filling up with BP Ultimate this afternoon and doing a 20 mile run to see if that makes a difference. The car does run perfectly.
My thoughts are that super E5 fuel which contains more detergents may have caused the odour from the PPF I’m certainly going to continue to use E5 fuel and see what happens.
R171 SLK280, Smart R451, 997 C2S, VW ID.5, R1250 GSA TE 40th, CBR600FP
Thanks Mike I didn’t realise but I know for next time, the car ran perfectly this afternoon so will continue with E5
Tesco Momentum 99 is excellent, and pretty much all I use in my 911 and CBR600
malcolm E53 AMG
malcolm E53 AMG
  • #466
Another day another recall on the E53 which is fan related again so MB appear to be struggling to find the right software update to regulate the temperature in the engine bay.
I also asked MB while the car is there to investigate the burning smell it seems to be coolant related to me so could be a leaking 48V water pump or one of the connections it’s situated in one of hottest parts of the engine bay directly below the turbo/exhaust although there is a heat shield in-between.
Car goes in Wednesday so we’ll see what they find.
malcolm E53 AMG
malcolm E53 AMG
  • #467
The car is back from the fan software recall and the fan now overruns when the engine is switched off for about 10 minutes the heat sink must be enormous in this weather.
Re the smell, all the undertrays and upper engine heat shields were removed and no there were no leaks whatsoever so a clean bill of health there. The A/C treated to an antibacterial clean and windscreen wash reservoir emptied and filled with fresh (it smelt rank apparently) and car handed back all for the princely sum of £145.
The 2 litre petrol GLA loan car was OK but the steering feel and pedal positions didn’t suit me I much prefer the throttle to be hinged from floor and the pedal set seemed high even for my size eleven boats. The wife really likes the high seating position so time to look at a GLC 43 again lol
malcolm E53 AMG
malcolm E53 AMG
  • #468
Results of the recall - looks like I’m a fully paid up member of the fan overrun it does this for 10 minutes at the end of most journeys. You have to smile the car is 6.5 years old with 47k miles on the clock so you might consider it a bit late to introduce a fan overrun lol.
Still I suppose you can’t complain at least they are doing something about the heat build-up in the engine bay and prepared to pay for it with a recall - as their strap line says ‘The Best or Nothing’ or is it called development in the field…
Srdl
Mine does it once or twice a year and then eventually stops after a couple of weeks. I’m still convinced mine is related to the Gasoline Particulate Filter.
malcolm E53 AMG
malcolm E53 AMG
  • #470
After the recall the fan stays on for 10 minutes at the end of most journeys which doesn’t surprise me looking at the location of quite a large turbo and the fact that the exhaust gases leave the turbo and are directed forward towards the front of the car into the gasoline particulate filter. The engine is quite a neat compact unit but it does generate a lot of heat due to the exhaust direction through the turbo/GSF layout.
I’m still not convinced there isn’t a problem somewhere there is definitely a slight of whiff of burning occasionally which could be exhaust gas from turbo or GSF seals or it may be when the GSF is doing a regeneration I’ll monitor it and see where we go from here.
The fan overrun is probably to stop damage to the turbo bearings from excessive heat sink after the engine is switched off probably more appropriate in warmer climates than ours although after last week I’m not so sure.
Car manufacturers in the US are facing class actions at the moment due to turbo engine failures now that they are moving away from large naturally aspirated V8 motors to smaller turbocharged 4 and 6 cylinder units which aren’t as robust and suffering a lot of failures given the high mileage they cover in the US.
malcolm E53 AMG
malcolm E53 AMG
  • #471
Thought it was worth a mention that all Direct Injection (DI) cars have a Gasoline Particulate Filter (GPF) fitted (>2018ish) so if you do a lot of short journeys as I’ve been doing lately the GSF will struggle to do a full regeneration. I’m pretty sure that was the case with the M256 in my car the engine ran well but wasn’t being run long enough to clear the filter so I used a local A road and ran the car between 3-4000 revs (up and down the box) for 15 miles.
The M256 AMG is a great engine but It will potter about on local roads around 1500-2000 revs which doesn’t build the 600+ degrees C needed to burn off soot in the GSF. So it looks like I need a new regime to keep the filter clear to include a monthly burn out as now it appears the GSF needs as much care as the DPF in diesels unfortunately with low mileage usage.
ALFAitalia
Pagham, Bognor Regis
2010 Mercedes W212 E350 CDI Sport
Only relatively recently. They only were on all MB petrols from 2018. They have been doing DI since 2003....in fact they did one in 1954 ...the legendary SL 300 Gullwing!...the very first road car to use it.
malcolm E53 AMG
malcolm E53 AMG
  • #473
Thanks, I fixed that in my text #471
Srdl
GPFs rarely cause the problems that DPFs do. I do a lot of shorter journeys interspersed with occasional longer runs and I only get the fan run-on once or twice a year.
This is Google's AI response to the question “Is GPF as bad as DPF?”
No, a Gasoline Particulate Filter (GPF) is generally much less problematic than a Diesel Particulate Filter (DPF). Because petrol engines naturally run significantly hotter than diesels, the exhaust heat passively "burns off" soot as you drive, virtually eliminating the aggressive clogging and forced regeneration issues notoriously associated with DPFs.
Here is a breakdown of why GPFs cause far fewer headaches:
Less Soot Production: Direct-injection petrol engines produce a tiny fraction of the soot that modern diesels do, so the filter has much less debris to process.
Faster Heat Generation: Petrol engines reach optimum operating temperatures much quicker than diesels, aiding in "passive" self-cleaning during regular commutes.
Minimal Active Maintenance:
While a clogged DPF frequently requires forced highway drives or visits to a mechanic for chemical cleaning, GPFs handle daily short trips and urban driving much better.
Performance: Real-world testing shows GPFs do not noticeably choke engine power or negatively impact exhaust sound compared to DPFs.
malcolm E53 AMG
malcolm E53 AMG
  • #476
Good to know, I do quite a few 3 mile journeys all three children live within a three mile radius so if I’m doing work there the estate is the chosen tool for the job I suppose I could always buy a E53e lol
I love the high gearing of the E53 but it also comes with low revs which is quite unusual for a petrol so I’ll continue to give it a blast every month. The car will be going up to Scarborough and Whitby early September so that will blow out the cobwebs.
Still mulling a GLC43 facelift but they are still really holding onto their value a 21 plate comes in at £36k
malcolm E53 AMG
malcolm E53 AMG
  • #478
Interesting that you mention this - a friend of ours is very keen on buying one of these.
My good lady wife would like a SUV and it makes a lot of sense at our age easy to get into etc so I’m looking at trading the BMW for one but the only one that stands out to me is the GLC43. They seem to be fairly bulletproof the V6 has been around a long time so you could say all gremlins are known and most ironed out and the facelift >20 plate is a lovely machine but the price remains stubbornly high even for higher mileage examples.
Woodleigh
S213 - AMG E 53 - 4MATIC - Premium Plus - Night Edition - Mild Hybrid Estate.
I just got back from a 48-mile round trip on dual carriageways, ‘B’ roads and some off-road with my 20-inch AMG rims…no issues.
Drove in both comfort and sport, and the average engine oil temperature was 104°C, and the transmission was 87°C.
Would you believe that when I parked up in the garage, there was no fan overrun, notwithstanding that I could have fried an egg on the bonnet, it was that hot to touch.
That being said, if I do get fan overrun, it mostly occurs after returning home after driving through slow-moving traffic in town.
ALFAitalia
That seems quite a high oil temp and right on the edges of acceptable "goldilocks zone" temperatures.....which ideally is 90 to 105c. Mine never gets over 95....but then its a big lazy low revving turbo diesel!
