Hi Nigels ,did you manage to get it sorted .I`ve got the same codes using the same scannerleft side is to low , right side to low, 555e13 says open circuit valve control. using a i car soft mb version 2
It was a valve block problem ..but the compressor had burnt out ..so had to have a new compressor and valve block .Hi Nigels ,did you manage to get it sorted .I`ve got the same codes using the same scanner
