Ticking noise
woosie
Wickford, Essex
Hello, this is my first post on this forum, hope you can help, I've owned a 'c' class 220 cdi '54' plate for 3 months now and I can hear a faint 'ticking' on the drivers side under the dashboard, somewhere where your knees are situated when you are driving the car, I first thought it was a stone caught in the tread of the tyre but the noise still sounds when it is at standstill, it is not loud enough to be that distracting but anyone with any ideas would be much appreciated, many thanks.
Ellsy Tanners
Mars
Hello, have you tried listening with the bonnet open, in case its and injector blowing,ticking. Can you hear it from outside the car, is it speed related or engine speed related or just constant??
I cant think of anything in the drivers underdash area that would cause i ticking as you describe.
philharve
Falmouth, Cornwall, United Kingdom
go.to
W202 C230K Auto 2000
Strange 'ticking' sound
I assume the 'ticking' is present only when the engine is running regardless of whether the car is in motion? In that case take a look under the bonnet.
REGARDS
Phil
W
woosie
Wickford, Essex
Had the bonnet up, can't hear no ticking noise in engine bay, also the noise is constant, it doesn't get any faster as the engine revs higher or when the car moves faster, also what I didn't point out in the first thread when you first start the car up it's ok, when it's warmed up is when the ticking starts, thanks.
jpbp200
North East
E220CDI BlueEFF SE Premium Estate/Auto/2015/Diesel
Have you left the indicator on! :)
Dec
Ireland.
W202
To see if there is an electrical source to the ticking, try removing different fuses to see if the sounds stops, when certain fuses are removed, the heating system would be a good place to start.
Dec
wolfetony
coatbridge scotland
my wifes c180 has a noise like a midget with a hammer coming from the panel behind the radio it happens when you turn the ignition on lasts for aprox 2mins then stops heater blowers air con etc all work fine car runs fine this only happens when you start the car up you cant really hear it from under the bonnet so i know its not the engine which seems fine also its not effecting the car,s performance in any way anyone had this problem or knows whats causing it any advice welcome its a 2000 x reg by the way
slk350
Are there any suspicious digital clocks in the car which are counting down? :shock: :grin:
A
Ashley H
My E class has a noisy fan for the climate control. Does it continue if you switch-off the heating & ventilation system? My independent has tried lubricating the bearings on the motor but apparently it needs replaced :(
wolfetony
coatbridge scotland
yes hers still makes the noise as soon as the speedo lights up no heating or ventilation turned on you dont even need to start the engine for it to happen but as i say it stops within 2mins, 100 yrds from moving off.
100%Bitch
Norfolk 'n' good
If it's a Rolex (only genuine please), bags I go half. ;)
sound 8
It could be the dash expanding an shrinking with heat and air con, my does it sometimes, try turing your fan off.
grayb
Kent
E350CDI (S212) 2010
I think our W209 CLK 2003 has a similar noise. In our case it is on the passenger side and is quite a loud rhythmic tick / clack that occurs when the ignition is turned on or soon after starting the car. The noise lasts for a minute or two. We asked the dealer who supplied the car - he had heard the noise and had the indie Merc garage who serviced it check it out. They said that they didn't know what it was but it doesn't happen if the Activated Filter button is on.
This doesn't sound right to me, so any suggestions?
gpharper
2003 CLK with Same ticking as described
In my case it happens when ignition is turned of, sounds as though it is coming from behind the radio? Again doesnt seem to be affecting the cars performance in any way. Still i would like to know what it is... within warranty!
Ellsy Tanners
Mars
You have a problem with the stepper motors which move the flaps or the heater system, they are common to break and give noises on the lk 209 and 203 c-class.
The stepper motors or gogs which they move have broken, depending on which motor or flap is broken, makes how much work is envolved in fixing it. sometimes just radio etc to come out, others the entire dash and heater box has to come out. Get it sorted under warranty as it will be a long expensive job out of warranty.
moneyman
Derby
Agree with the above. Had this problem on my CLK but noticed it when I was buying the car so the dealer fixed before I took delivery. It was a dash out job. Looked very scary when I saw it but it all works fine now.
carleton
New Registration
bristol
c320/2001/3200
I have had this on my Jeep CRD which is high percent Merc.
It turned out to be the heater blend doors. my Merc C320 is doing it as well, I will be looking for that fault, its behind the radio at the top of the dash some where.
I will post my results.
Tel: 020 8863 9233
