tilt & slide sunroof problem !
Status
Not open for further replies.
Neil
Wales
The tilt/ slide sunroof unexpectedly stopped mid slide - since closed by hand. I have connected a supply direct to the motor and all appears well (it worked !) - the loom/ switch also sends a current yet the roof does not move. Problem is therefore - possibly - position sensors built into the loom ? anyone with a wiring diagram/ helpful hints or suggestions ?? (extremely remote location 100 miles from nearest merc garage !)
David Halsey
TRY CHECKING THE RESISTANCE ACROSS THE SWITCH WHEN OPERATING, SOMETIMES THE SWITCH APPEARS TO WORK, BUT, HAS SUCH A HIGH RESISTANCE THAT THE UNIT WILL NOT OPERATE
Status
