timeing chain location
vito108cdi
hi can you please tell me were the timing chsain adjuster is on a vito 108 cdi thanks
V
vito108cdi
i cant see it lol on the top of the engine or the bottom and is it near the alternator belt? thanks
Let me have an Email address and I will send you the details
V
vito108cdi
thanks ........
I have sent it :D:D You can go back to your post and delete your address in "edit" with 2 hours
I think you have to reset them once they have been removed, or is that just the petrol?????, best to check before you bugger the chain up!
I sent him the correct sheet with the re set details on it
Top man Malc, people forget they have to be reset!!
V
vito108cdi
hi i cant find it lol do i have to take any of the pulleys off? also is it same for the 108 as the 111? thanks guys
V
vito108cdi
is it the same for the 108 as the 111? as i cant fint it cheeers
I made a mistake on the paper I sent, you have the 601 engine, 2 correct ones sent, not a good day yesterday
V
vito108cdi
think i found were it should be i undid a alenkey out but there is nothing inside its just like a plug. any ther ideas?
What is the problem on the engine
V
vito108cdi
the engine rattles from the chain so i thought it would be the tensioner?
From 150k miles and on the timing chain can stretch, and this causes the rattle, mainly from a cold start up but should go when the oil pressure has built up, after a few seconds. This is how they start off, it is seldom the tensioner that fails.
Is there any difference between a cold start up and after it has been running sound.
The Idler gear on the front for the belt causes more rattles than the chain.The info for cars is much easier than for the Vito due to the variations in the amount of Vito's, often the alternator has to be removed to get to the tensioner.
I will see if I have any better info tonight
V
vito108cdi
cheers well ino that it has not been replaced on the van so i recon the chain has streched and the adjuster is worn or whatever?
I do know that the drive shafts have to come off to get to the alternator that is in the way of the chain tensioner, its quite a job but a few have done it
V
vito108cdi
  • #20
i got the alternater off and got the tensioner out it is fully out so im guessing it needs a new one. i think the rubber plasticy shoe need changing aswell does the engine need to be stripped for this?
www.ckinsurance.co.uk
