Robuk22
- Aug 16, 2018
- c-class coupe 2012 1800 t
Hi Guys,
I am trying to find the cause of early timing chain failures on the M271 cgi engine also known I believe as the M271 evo. This engine is said to have a redesigned chain tensioner but problems with the timing chain/tensioners are now occurring earlier (45,000 miles) than with the Kompressor engines, I am trying to ascertain whether the stop/start function is responsible for this earlier failure. My chain on startup is normal with no rattle at 41,000 miles, I disconnected stop on the first week of ownership.
Has anyone had a timing chain/timing gear failure on this later engine, post Sept 2011 blueefficiency with stop/start, if so.
1, Did you predominantly have stop/start engaged and working, what was the year and mileage?.
2. Did you always turn the stop/start function to off, what was the year and mileage?.
