Hello all,
My SLK 200 (171) ‘05 recently started making a subtle rattling sound when I turn the engine on. The rattling does not go away after the first couple of seconds or when the engine warms up but continues. It is rather subtle though and you can barely notice it when in the car. When you open the bonnet is more noticeable.
I took it to an independent mechanic specializing in Mercedes and said that is probably the timing chain. I will take it back for further inspection (remove the valve cover, measure tension of chain, examine condition of sprockets etc.)
If it turns out to be the chain and the sprockets also need changing, could you recommend a OEM timing chain kit with sprockets (or separate)? Genuine parts are not an option because of the cost.
I see many OEM kits in the various sites (VAICO, FAI, Febi Bilstein etc) but have no idea which ones are good.
Given that this is a common failure with the M271 engine I imagine there is ample experience with such kits in the forum.
Thank you.
Yiannis
Thank you.
Yiannis
