Tire Pressure Display/ Sender Modules
W
willidav
My display shows need to reset the tire pressure sensor, I did once but the error is back and it never did display the pressure. How can I check the sensors, or disable the error code so it is not always displaying? This is on a 2003 SL500. Any help is greatly appreciated::D
rf065
Grossbritannien
Did you reset it & take it out to learn the new settings?
Maybe yours is a different system from mine as mine does not display the tyre pressure, only warns you if the tyre loses pressure. It measure wheel rotation from the ABS sensors, and can tell if a tyre is losing air from that.
Russ
If it is done correctly it should tell you the faulty sender,,you use the mileometer button to set it
W
willidav
Tire Pressure Sender Issues
Can I totally disable the function so I don't see the errors? Thanks
Yes you can I hate the things,,I had mine turned off on STAR anyone with STAR can do it in a few mins
