turbopete
- Feb 4, 2009
- Age
- 50
- Location
- Spennymoor
- 2022 '71' Ford Grand Tourneo Connect (sorry)
As many of you are aware, i have a problem with air being sucked into the fuel when the engine is revved up ie when driving and often seems reluctant to start when facing downhill. this fact may or may not be relavant to this query.
on 3 occasions (so far) since ive had the car its failed to start, and been reluctant to the point of almost not starting on more occasions than i care to think about! this scenario of difficult/non start always occurs when the engine temp reads in the area of 80 or more on the guage. if i realise this fact before i flatten the battery too much, leave it to cool to 60 or 70 degrees it starts as normal (for my car that is, not normal for an e300td)
also over the last couple of days or so, it seems to have been running cooler than normal. this, again, may or may not be related. its always sat at around 80 on a run, slightly hotter with air con in use. lately ive used aircon every day and now its running at 70 degrees (on the guage) however the starting problem (my main concern) has been there since ive had the car!! can anyone shed any light on the problem? i cant afford to spend much as work is very limited, and what jobs i do get i need the car to be reliable to get me to them!
