TOMB NEWBIE
All Warning lights on - Can't get into gears on auto box - New Battery COLD
  • Fitted New Battery but no go next day -
    Votes: 1 100.0%
  • Warmed up battery with hair drier - Enabling gear selection
    Votes: 1 100.0%
  • Total voters
TOM BELL
E220 Coupe 2012
I have had 5 Mercs but currently own a 2012 E220 Coupe Auto
A.J.
Norwich. UK
Nice one Tom, welcome to the forum :)
T
TOM BELL
E220 Coupe 2012
Thanks Andy
Any idea why all of the dash warning light come on (even though the engine starts and runs fine) but it won't let me select any of the auto gears.
Fitted a new battery two days ago... all seemed fine until I started up tonight... back to being unable to select gears again.
So I heated up battery with a hair dryer and the warning lights went out and I drove home.
Didn't get any lights saying that battery wasn't charging.
A.J.
Norwich. UK
I wish I could help you Tom, I am not a techie by any stretch of the imagination. There are many who are so I am sure your wait will not be long :)
T
TOM BELL
E220 Coupe 2012
Thanks again Andy... I'm not techie either but I have a tame retired Merc mech... But this has got him stumped
John Laidlaw
Wirral
Land Rover Discovery 4
Welcome Tom
Bit odd on the heating front and intermittent working but otherwise I’d be checking to see if any fuses have blown, somethings happened in the battery change I’m guessing -Did you try to disconnect and reconnect at all? Is the new battery full?
Others will be along shortly with ideas
T
TOM BELL
E220 Coupe 2012
Welcome Tom
Hello John... thanks for responding.
You ask if the battery is full... Do you mean fully charged up? It is a brand new 80Ah 800A Stop/Start (£185).
Fitted last Saturday... worked fine on Sunday and getting to work and back on Monday. (20 miles)
But come Tuesday after work it started fine but all of the warning lights came on again and it "locked" in Park so I couldn't get into any of the auto gears.
Had to heat the battery up with a hair dryer and all the warning lights went out after 20 mins of warming it up. (So I went for a 30 mile drive to charge it up and it's ok this morning).
John Laidlaw
Wirral
If it’s fine today then it can’t be fuses then.
I’m wondering about corrosion on one of the battery connections, maybe the hair dryer was enough to blow it away or heat it off maybe. Did your tech run a diagnostic?
Check the battery earth cable to make sure the connection to the body
That would be my next thought.
Check condition of the earth and power cables and where they bolt to. Heating may be expanding them to get a better connection to allow it to work.
T
TOM BELL
E220 Coupe 2012
Hello again John
Just had my tame Merc Engineer check out the battery with his tester... all ok.
He then checked the Alternator... all ok.
Car running fine at the moment... no warning lights.
He tells me that if the voltage drops below 9volts? the battery will start the car but shuts down heating, internal lights, ABS etc etc.
He also checked the boot light and the boot lid red warning light... they went off when he jammed a piece of wire in the boot lid lock.
I have had 5 Mercs... loved them all ... never had any trouble with the battery getting cold.
How can Merc design a car that starts but shuts everything down leaving you stranded!
T
TOM BELL
E220 Coupe 2012
Thanks LostKiwi
I'll ask my mech friend to check them out right now... He's been here all morning looking for the fault.
Thanks LostKiwi
Also look at what else is getting heat from just being in the vicinity. Anything with a soldered connection could be suspect as dry joints commonly work when warm but not when cold.
T
TOM BELL
E220 Coupe 2012
Thanks LostKiwi
Just checked the battery earth and power cables are well connected. all ok
T
TOM BELL
E220 Coupe 2012
OK LostKiwi... Thank you... we will get on it right now
T
TOM BELL
E220 Coupe 2012
He has checked all the cables in the vicinity... no apparent issues
T
TOM BELL
E220 Coupe 2012
I have just driven from Oxford to Winchester and back (100 Miles) in an attempt to make sure the battery is charged up for the morning drive to work... Fingers crossed.
T
TOM BELL
E220 Coupe 2012
  • #17
I forgot to mention that this was all happening with the old battery BEFORE I changed it. - And was the reason that I changed it ... so the installation of the new battery should have sorted the problem.
One question - does it require the heating of the battery or will he issue go way without that? Where did the idea of heating the battery come from?
If you measure the battery voltage what is it?
T
TOM BELL
E220 Coupe 2012
  • #19
The "No Gears" incident happened last Thursday morning... Left the car at home and took bus to work.
My mechanic came round when I got home... we ran the engine for 30 mins before I could select a gear in auto.
He checked the battery and concluded the system locks the gears as a safety feature because ABS etc are "inoperable".
He told me that this happens if the temperature is low (Was below freezing at 4.00am last Thursday) and the voltage falls below 9 volts.
Thinking that being warmer might help... when I couldn't get into gear on Tuesday (3.00pm but probably +2 C) I got a long lead from work and heated the battery with a hair dryer... after 15-20mins I was able to select a gear and all of the warning lights had gone out.
I have been to Inverness in all my previous Mercs below -0 C in the winter with no trouble starting etc.
I have had this E220 Coupe for 18 Months with no trouble up to now???
The Battery voltage was 14+ on the tester.
Was that before you started the engine or after? Whats really needed is the voltage before starting and then again 2 minutes after starting.
