Touch up methods
johno2004
SLK32 AMG
Would like some advice on stone chip touch up.
Have a 1997 CLK320 in metalic blue and there is no rust what so ever on car but it is suffering with age related stone chips and i want to sort these out.
Would it be best to take to body shop or buy colour coded touch up paint and do myself.
Where also can you purchase the correct colour touch up paint ?
Any advice welcome
Johno
jibcl500
Cambridgeshire
CL500,ML55,SLK280
I do mine myself, use a cocktail stick to apply the paint and build it up over a period of days to get the height back, I use rubbing compound to polish it smooth, this can leave the area dull. I tehn polish it back using specialist compounds and polish. The results are good and just about invisible but time consuming to do. I only had 8 to do.
jib
You should not attempt it at temp below 17c as the paint hangs around too long and the solvents can melt and soften the area surrounding it
johno2004
SLK32 AMG
Thanks for input
Will wait for spring i think, but will get a quote from body shop to see if the price is reasonable and go from there.
42864
Pembrokeshire West Wales
re: your last message about waiting until Spring. Apparently the law changes and ALL paintshops have to convert to use Water Based Paints on the 1st January 2008, so if you want a proper paint job done with good paint (not Water Base rubbish that chips so easily) you need to get in fairly quick.
JEZ.S320L
Costa Calida, Spain
www.latorreonline.es
Any advice welcome
Johno
Halfords do an excellent touch-up kit. It has a fine brush, and an even finer pen nib. Around £8'ish.
David Nock
South Yorks
CLK/2009/320CDI
I've got by and pratted about over the years with touch up paint which gave servicable results, but never got top flight results like a body shop job. And of course metallics are harder to blend in than solid colours.
If your car is worth doing well and for extensive number of chips, I'd go bodyshop route.
johno2004
SLK32 AMG
Tanks for advice,
Will body shops be interested in stone chip repairs ?
A210AMG
Johno,
Body shops will be interested but would rather concentrate on a panel or at least an area they can mask off and match up. If its the basically the front bumber and edge of bonnet I would suggest getting a quote from a good body shop.
One of my old boss's use to do this to every car he sold, had them sent to a bosy shop and valeted, the cars looked like new when he sold them :)
You can do this work in the colder weather but you do need a heat lamp, that said, its not easy doing stone chips on the bonnet as you need a stand for the lamp, the main thing to remember is that what body shops do is no magic thing.
You use the touch up with a end of a nail and just put a drop in the damaged hole, then go away and leave it to dry 15 mins at over 20c, then very lightly T cut the spot. Apply another drop, leave for 2-3 mins ar 20c and wipe the spot with your finger to smudge it, then leave for ½ hour (20c) then just lightly T cut again, this base coat rubs of like butter, so not to hard and you will find the the mark is the same colour as the original. Do not apply the cellulose based top coat asthis will make the repair look too dark and you cannot blend it, just leave it in the Base coat, then polish and you will hardly see it.
I tried to take some photos of the process but the result were so good you could not see it, I will try again and write something up
johno2004
SLK32 AMG
Thanks Malcolm
Where is the best place to buy colour matched paint ?
Thanks Malcolm
The little packs that Halfords sell are good and exact thats if you want a little brush to apply it, cheaper to by an aerosol, shake it well and spray some into the cap, than use you own brush.
The packs are good, but you will never use the clear
The paint code is on the b door pillar, first number
SimonRaf
Belfast
CLS 220 Bluetec AMG Line Premium Plus - Palladium Silver
Would def go for this. Got it myself for a previous car. Make it up on the spot and a perfect match.
philharve
Falmouth, Cornwall, United Kingdom
go.to
W202 C230K Auto 2000
Halfords touchup kit
Tanks for advice,
Hi johno2004
My MB dealer said 'yes' to the task of treating stone chips but they let me know it would cost me dearly and I would be better off doing it myself. The best advice I've ever received from a dealer.
I eventually had the bonnet resprayed and after a year it is still spotless. That cost me dearly too, about GBP350.00, but the bodywork looks like new.
Dealers sell touchup paint as do indies. I have a Halfords touchup repair kit but have never tried it. There are 2 or 3 philes in a plastic container, one contains a rust inhibitor. I think the other two philes contain undercoat and top coat. The kit looks as though it will do the job.
REGARDS
Phil
philharve
go.to
Hi All
I have a couple of little scratches above and below the fuel filler cap, maybe half-an-inch long, almost as if someone has tried to prize the filler cap open. There's no damage other than the colour coat removed.
Should I apply touchup in layers over a period of days or should I do it in one application? With the weather as cold as it is, I will wait until the temperature is warmer.
REGARDS
Phil
johno2004
SLK32 AMG
  • #18
Have done a closer inspection on my car locating all stone chips to take to take to a body shop for quote and on close inspection have noticed slight bubbling on one of the rear wheel arch.
The car has done very low milage with all history old mots from 3years and and the condition of the car it looks like it has done the 55k it states.
It is a 1997 on a R plate does this come in the 30 year rust warrante that mb say they give or is the car to old.
Dont want to go to mb dealer and look like a pra** asking for something im not entitled to.
Is it worth a try or would i just be wasting my time ?
Hi All
REGARDS
Phil
Only try and use the base coat colour, it shrinks when it dries, so you have to do it in several stages, scratches are very hard due to the shrinking action and the paint pulls back form the sides of the scratch, if you only use the base coat,it will always T cut off..
When we spray cars the scratch has to be sanded out, otherwise it will always grin through
Xtractorfan
S class
As a bodyshop owner my advice would be, by all means get the touch up paint paint stick from halfords or even MB touch up the chips yourself, let them dry and see how they look, any that are a mess can be removed with a little bit of thinner and attempted again...but it is hard to beat a professional repaint of the panel. if the rust/stone chips are all on the front end , front of bonnet, wings et. you're never gonna make a job of it by touching it up, get a few quotes from different shops, ask if they do work for any of the local garages, and walk away if you are told that half of the car has to be repainted just to match a panel. if they do trade work, chances are they do a quality job. but its not a guaranteed recommendation. and I have to diss the chips quick touch up guys here. you cannot properly touch up a scratch/ stone chip by blowing a half coat of watered down single pack lacquer over it...great ifyou are selling the car next day but dont attempt to keep it too long.........
