traction control coming on why!
paul vp uk
dualinern04c class elegance 1997
the orange traction control light keeps comming on when i do over 70 for a few minutes , then stays on untill i switch off the igmition. when i restart its out.
i have on done 500 miles in her so forgive the newbee question.
04 dualliner vito
turbopete
Spennymoor
2022 '71' Ford Grand Tourneo Connect (sorry)
id guess that theres a tyre badly worn relative to the rest! this could be enough to spoil traction control lights though!
paul vp uk
paul vp uk
cheers bud does the light mean
is it a fault then ?
paul vp uk
paul vp uk
off to read hand book?
sat having breaky as above had a traction control light come on
its the first five hundred miles with her so still learning.
got a cuppa and the hand book to see if i am doing something wrong or i can switch the traction control off?
enjoying my cuppa!!:):)
turbopete
Spennymoor
if you switch it off, the light will stay lit on the dash. it will need to be switched off every time you start the vehicle too!
having thought about it some more, it could be a dirty or faulty wheel sensor or ring as if i remember right the traction control takes its readings from these, the same as the abs system does!
paul vp uk
paul vp uk
Thans Pete.
been out today and kept her under fifty. no light.
maybee a brake caliper sticking a bit used to happen on my disco when we had been through a lot of water.
anyway will keep an eye on it.
she allows me to turn the t/control off when parked,
having to get used to all these sensors, comes with territory.
Good news
mpg looks great 35MPG
and a lot smoother since popped a tim of desiel injector cleaner in her.
pleased just need to get the initial worries about massive expence stories out of my mind.
best van i ever had !!! SMOOTH AND COMFY
turbopete
Spennymoor
mercs arent as expensive as people think for parts! some things can be a bit steep, but then again they can with any other make you can think of! overall, they are a nice place to be and should be enjoyed whenever possible, even if they are a workhorse!
