R W
- Nov 23, 2005
- Location
- Amble,Northumberland
- 2001 E320cdi/ Sclass 2012 350cdi
I have been enjoying driving my E class for the past 2 weeks but experienced a few transmission shift change problems. Twice I have accelerated up through the gears & when it was getting close to where the transmission would have changed into 4th I have taken my foot off the accelerator to slow down. On these two occasions the transmission appeared to select neutral or no gear selected. It would coast for a while & slowing down, the transmission would select the correct gear & drive OK again. The two occasions were days & many miles apart.
On Saturday on two occasions it locked its self, once in 3rd ( I think ) & once in 4th gear. When it did this it would not change up or down automatically or manually. On switching off the engine & restarting it runs perfect again & has continued to run OK for the past 4 days & maybe 200mls no problems at all.
The car has stood unused for 2months but was connected to a battery trickle charger during this time & I have had the battery tested & seems to be OK so I would tend to rule out a low voltage. The car is a 2001 E320cdi with 177K on the clock. Transmission oil & filter was changed 8k miles ago & old oil looked OK.
I have it booked in for the oil level to be checked & diagnostic check on Friday but wondering is any of you technical guys would have any ideas on the problem.
Thanks in advance for any advice.
