BRABUS R230
- Feb 27, 2009
- Location
- London
- BRABUS SL55 K8 (R230), SL500 (R129), B Class B200 CDi, VW T5 Transporter.
I noticed that when I put my car in drive from neutral it engages with a hard jerk...almost as if my foot was on slightly on the accelerator while putting it in gear, but the rpm are at around 750 in neutral then drops to around 500 rpm when in gear.
My car is now stuck in "Limp mode" and remaining in second gear while driving, (I cannot change gear other than reverse) only with error code P0715, apparently this code relates to the transmission electronic plate speed sensor, (whatever that is. )
not sure if related but my problem started after having a new alternator fitted, and having the plug and pins replaced on the lead connecting to my long ago upgraded 82mm throttle body.
is this P0715 code indicating a big issue with my gearbox...is this speed sensor inside the gearbox...or could the problem be elsewhere?
just seen this. "P0715 Input/Turbine Speed Sensor Circuit Malfunction"
