Transmission leak 1999 E430
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by Jpatryas, Nov 16, 2012.
  1. Jpatryas
    Jpatryas New Member
    5
    Nov 27, 2011
    Florida
    Your Mercedes:
    1999 E430
    My Daughters car has a Transmission leak. If my husband changes the plastic housing that holds the electrical connections to the transmission will it leak fluid when he takes it out?
  2. jibcl500
    jibcl500 Senior Member
    6,420
    6
    Oct 22, 2005
    Cambridgeshire
    Your Mercedes:
    CL500,ML55,SLK280
    Yes once the bush is removed it can leak some AT fluid so make sure you have a tray to catch what comes out, it wont be much but top up with fresh ATF once new bush is fitted also clean the plug as this will have oil inside.
    jib
  3. bigasotonuk
    bigasotonuk Senior Member
    5,243
    9
    Nov 14, 2006
    Southampton UK
    Your Mercedes:
    C43/55 AMG 1999 / C230K 1997
    Had mine changed, you will lose fluid but not much, the amount i lost was minimised because the car was jacked up on one side which limited the amount of oil that came out, I caught what came out and put the same amount of new ATF back in the gearbox.
Share This Page
