Transmission/ Workshop Required
Tree cutter
B class 180
My partner was driving her Mercedes b180 CDI SE to work this morning from Ashington Northumberland to Whitley Bay & the warning message came up, Transmission Workshop Required. She said the car was juddering & when slowing down, it felt like it was going to stall.
Anyone know of any independent mechanics near us to look at it please
Sent from my SM-S901B using Tapatalk
T
Tree cutter
B class 180
  • #2
Just to mention, the engine management light didn't come on. Do we need to be concerned?
ajlsl600
france
Have codes read see wot comes up photo all seen, delete try again if same fault reappears, find out why.
T
Tree cutter
B class 180
Where is the port for diagnostics please
T
Tree cutter
B class 180
Plugged a OBDii V310 diagnostic machine in car & no codes came up.
Puzzled
FlorinM
Cheshire
2014 C250 CDI Amg Sport Edition (Premium Plus)
You need to read codes with a diag tool that can read all control modules in the car not just engine, since then error is coming from the transmission.
This fault code on these usually means the follwoing actions:
Depending on fault codes, and if even gears are missing (no 2nd/4th and 6th, a software update.
then an oil and filter change
if not those, then one of the actuators is likely failing.
T
Tree cutter
B class 180
Just put diagnostic on & saying it cannot connect. Why is this
