Trouble with P0172 code
abtekk
New Registration
C200/2002/2.0ltr Kompressor
Car
Make: Mercedes
Model: C200 (W203)
Year: 2002
Engine: 2.0ltr Petrol - Kompressor
I've got trouble with my car. The MAF sensor failed with error P0101, I ordered and fit a replacement MAF and the engine started running extremely choppily and losing power when trying to pull away. The CEL came back on with error P0172. However, putting the old sensor back on brings back P0101 but the engine runs smoothly.
Is this a problem with the new new new (I've had 2 replacements) MAF sensor, or is it revealing a deeper seated issue with the car?
mattkh
England
A160 W168 1999 1.6
What is the mileage.
Is it possible to put up a picture of the electrical connector to the MAF preferably unplugged.
Steve@Avantgarde
Bristol/Somerset
C220CDI AMG Line Premium, SLR McLaren Roadster, SL55 & C32AMG
Non OEM MAFs cause problems, but you also need to reset the adaptations (that isn't the fault codes) because the ECU will learn values of the old failed MAF. It will readapt over time but that is why you get the lumpy idle and poor running.
The other thing to remember is that just because the MAF code is there, it doesnt mean that is the fault. On the old HFM systems it used the MAF to trigger engine lights and limp mode by removing the signal line. It will then store a fault code to say that it has done so. Which then triggers a merry go round amongst amateurs trying to fix their car.
We are a completely independent Mercedes Benz service, Mercedes repair and Mercedes MOT centre located in Warrington, Cheshire and have been established since April 2006. All servicing carried out by MB Tech is in accordance with manufacturer service schedules and carried out by Mercedes Benz trained mechanics.
Contact MB-TECH on 01925 653050 or visitwww.mercedesservicingwarrington.co.uk
