onejayster
- Feb 20, 2009
- Location
- Shropshire
- SLK 230 Kompressor R170 1999
Hi to all,
I have an ongoing problem with my 1995 Mercedes C220 Sport Automatic (W202).The problem with the car is that sometimes it can run fine and other times it’s damn dangerous to drive!
Unfortunately, the car has now got to the point of being 75% of the time dangerous and 25% as normal! It’s been gradually getting worse over the last couple of years.
The car will normally start fine (although the exhaust smell is very “petrolley”) if it has not been run for 5 or 6 hours and drive faultlessly. However, if you use it again before the 5 or 6 hours have elapsed it becomes an unpleasant experience. The car will start but sounds more Lada than Mercedes! The idle is eratic, almost dropping to zero rpm but just catching itself before stalling. The exhaust still smells “petrolley” by the way. If you put it in drive or reverse it will sometimes just about move itself but more often than not stall, very annoying backing in and out of spaces on car parks etc!! It’ll restart but still be lumpy!
The car will also stall when coming to a stop at junctions, no warning just dies as the car almost comes to rest. If it doesn’t die it almost does and then when you hit the gas again it’ll stall, not good at roundabouts and junctions, hence saying it is dangerous! Having to shove it back into park before restarting whilst someone bears down on your drivers side is particularly unpleasant!
It doesn’t end there!! When on cruise it’ll be going along seemingly fine at 50 to 70mph but then it’ll just lose power, almost as though you have your foot off the gas (even though you haven’t moved the throttle) but worse, seems to really hang mid cruise but then it picks up a few seconds later and it’s ok again for a few more miles.
Also for info it struggled through it’s emissions this year too.
I’ve done the following so far in a fruitless attempt to fix the problem.
1) New ignition leads
2) New spark plugs
3) Cleaned and rebuilt the throttle body - twice!
4) New Mass Air Flow meter
5) New air filter
6) New lambda probe
Can anybody suggest what to try next other than scrapping the thing as this is not really an option at the moment?!!?
I’m thinking ignition coils or crank angle sensor. I keep thinking i’ve fixed the problem only for it to come back a few days later!! I need some help please from someone with more knowledge than me on this.
If anybody has any advice please please post on this thread or pm me!
Thank very much in advance to anyone who feels they can help!
2) New spark plugs
5) New air filter
6) New lambda probe
