Trying to connect phone to 2007 a class
Lisar13
A class 150 2007.
Hi I have just got my a class 150 2007. It doesn’t have a phone bracket but has phone buttons on the steering wheel and center panel. When I try to connect through Bluetooth it says “no phone “. Does anyone know what I need to do. I’m not very technical. Thanks
Is there anything in the cars manual to explain it ?
V6Matty
Newark, Nottinghamshire
So the won’t have a phone even though there is the buttons for it, on the 169, if the phone prep was installed at the factory it would be in the centre armrest tray that pops out.
HankScorpio
W211 E320 2007
In this thread, somewhere near the end, I say how I got phone, DAB and streaming connected to my 2007 E Class.
Cost me £50 in Eze-DAB, couple of quid in connectors from Halfords and an hour or so of time.
L
Lisar13
A class 150 2007.
No. I think because it’s an iPhone I might have to install something.
L
Lisar13
A class 150 2007.
Thanks. I will have a look.
V6Matty
Do you have command or audio20 in the car? If you have a look in the glovebox you may see an AUX in port that might make the above option possible, if not then it may well be easier to upgrade the entire head unit to something more modern
L
Lisar13
A class 150 2007.
Hi yes I do. So do I need to buy a aux lead then it will connect thanks E657B718-E6DC-48AB-A65C-AE5F7DEA09CF.jpeg
V6Matty
There are some adapters that would work with it but I think it’s more for streaming music, you still won’t be able to use the button to make or receive calls with that I’m afraid
L
Lisar13
A class 150 2007.
I really appreciate your help with this
HankScorpio
W211 E320 2007
That aux socket is an input only. You will be able to play music and hear people talking on your phone, but you won't have a mic (and will need to dial via the phone).
The box I posted plugs into this aux socket for phone, dab, etc. Power is via the cigarette lighter.
As I didn't want wires floating around my car... And also wanted to keep my lighter free for other things, I removed the aux socket from the little plastic holder and taped it being the glovebox. I also bought a new 12v lighter socket for £6 on amazon and tapped this into the back of the existing lighter socket... It was pretty simple and is very neat.
V6Matty
I think your easiest option would be to update the head units, good ones with integration to the buttons can be bought for a couple of hundred pounds now and are relatively easy to fit with widely available connections, you could even go as far as getting ones with Apple CarPlay so you have everything on the screen and then your phone is no longer a distraction
