carabind
help please
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330101927634&fromMakeTrack=true
I have seen this item on ebay, promising enhanced performance :
ie
This chip takes 5 minutes to fit and can be removed when ever needed, there is no risk and it is cheaper than an ECU remap almost half price while offering exactly the same performance improvements. Some ECU remaps require the ECU to be opened and a chip to be removed for reprogramming.
This comprimises the integrity of the ECU while putting the ECU electronics at risk from Electrostatic which is capable of destroying the ECU.
A simple plug a play device offering the same performance as a remap has to be the way.
Power delivery is improved widening the power band, which result in less gear changes
No ECU error code are stored as a result installation
Uses genuine MB vehicle plugs and sockets making it easy to remove for service and MOT's and can easily be transfered over to other vehicles
The protective functions of the engines are kept
Hidden installation
The installation can be done for approximately 2 minutes (even a non-expert can do it)
Includes a detailed fitting guide with pictures
Easy uninstall for MOTs Services easy to move between vehicles
The fuel expenses are not increased in fact a 10-15% saving can normally be seen under normal driving conditions
Increase of maximum speed and acceleration
No soldering or stripping of cables needed, only fitting the inline device
My question to all is, do these work, what's the experience of those who have used them so far?
ie
Hidden installation
