D
daneland
Hello
A few months ago W251 (280 CDI 4 Matic) started to go into limp mode.Initially it was very rare but now it is happening every day.I took my local indie garage and got following code
2510 check component y77/1 boost pressure regulator signal fault (current)
I did a bit of research and found out that it is likely to be a turbo actuator problem which looks like a common fault.http://www.ecutesting.com/mercedes_e220__e270___e320_tur.html
As far as I am aware of it is not supplied alone brand new and I have to buy a new turbo or it needs to be repaired.
If I need it ,is there any place anyone could recommend for that sort of job?
Or generally speaking am on the right track to solve the problem?
Many thanks in advance.
