joderest
- Apr 16, 2018
- ML270 2003
Looking for some help here.
I have a small oil leak on the Turbo. I think I have tracked it down, will try to explain
If you look at the top of the Turbo, between the two bits, the forward housing has a back plate secured with four 8mm bolts. The bottom outside bolt is wet with oil and it drips down onto the Turbo activator. Its a very small leak, couple of drips in 100 miles or so.
I cannot see any wetness other than on the bolt head. I did try nipping it up and got half a turn which I thought had sorted it, but leak back again.
Any thoughts out there
