Turn key, all dash lights up but does not turn over
GMike
Suffolk
59 plate C220 Sport estate
Hi
Have a 2009 C220CDI Estate Sport.
I insert the key, foot on brake, turn the key and all the correct dashboard lights come on but nothing. I can do this 2-3 times before it starts to turn over. When warm it starts first time.
Its not particularly cold when it happens and does not happen all the time
Appreciate any guidance as sure this has happened to others
thanks
Mike
Starter relay, solenoid or starter motor.
G
GMike
Suffolk
thanks, its with a garage to find out which is failing
G
GMike
Suffolk
I am hoping that is the cheaper option:)
BClassChris
PRESTON Lancashire
Mercedes B180 CDI (2009)
️agree with what John has said have you checked the battery the cold kills em off and then they struggle to start in the cold weather - they might just have enough life in em to start when it’s a little warmer
Available at: https://zeppelinit.com
Hope you have a great day
G
GMike
Suffolk
Just been advised that it appears to be an ignition problem-possible known for Mercedes-where fails to communicate and therefore possible need for new unit. It is now going to a specialist to confirm
G
GMike
Suffolk
The winner is LostKiwi-it was the starter relay
thanks for the many responses, you are all excellent
Happy Monday
